When you derive from a KcsIO class, the mandatory external entry points are:
extern long KcsDLOpenIOCount;
KcsIO *KcsCreateIO(KcsStatus *aStat,
const KcsProfileDesc *aDesc);
The KcsCreateIO() method creates an instance of a KcsIO derivative. The instance is determined by aDesc->type, which contains the derivative portion of the class identifier (see "Creating OWconfig File Entries").
