A single script command consists of the command name (including the colon), followed by one or more keyword/value pairs. A keyword is separated from its value by an equal sign (=). Each keyword/value pair ends with a semicolon (;).
The basic script command format is shown below:
COMMAND_NAME:keyword=value; keyword=value;
You can free-format test scripts. That is, you can insert any whitespace character into any script command.
Example 2-2 shows an actual test script that demonstrates some of the script commands and their associated keywords and values.
LOAD:Reference=scanner; Profile=mtk600zs.inp; Handling=File;
LoadHint=AllNow;
LOAD:Reference=monitor; Profile=sony16.mon; Handling=File;
LoadHint=AllNow;
CONNECT:NAME=scan-mon;
Count=2;
Reference=scanner;
Reference=monitor;
Operation=FORWARD;
EVAL:Reference=scan-mon;
SourcePixLayout=RGBInterLeaved;
DestPixLayout=RGBInterLeaved;
Callbacks=;
ImageIn=rhg_mtek600;
ImageOut=rhg_mon.tst;
Operation=Forward;
FREE:Reference=scanner;
FREE:Reference=monitor;
FREE:Reference=scan-mon;
