GSS-API Programming Guide
GSS-API Status Codes
Major status codes are encoded in the OM_uint32 as shown in Figure B–1.
Figure B–1 Major-Status Encoding
Diagram shows how major status codes are encoded in OM_uint32.
If a GSS-API routine returns a GSS status code whose upper 16 bits contain a non-zero value, the call has failed. If the calling error field is non-zero, the invoking application's call of the routine was erroneous. Calling errors are listed in Table B–2. If the routine error field is non-zero, the routine failed because of a routine-specific error, as listed below in Table B–3. Whether or not the upper 16 bits indicate a failure or a success, the routine might indicate additional information by setting bits in the supplementary information field of the status code. The meaning of individual bits is listed in Table B–4.
GSS-API Major Status Code Values
The following tables lists calling errors returned by the GSS-API; that is, errors that are specific to a particular language-binding (C, in this case).
Table B–2 Calling Errors
Error
Value in Field
Meaning
GSS_S_CALL_INACCESSIBLE_READ
1
A required input parameter could not be read
GSS_S_CALL_INACCESSIBLE_WRITE
2
A required output parameter could not be written
GSS_S_CALL_BAD_STRUCTURE
3
A parameter was malformed
The following table lists the routine errors (that is, generic errors returned by GSS-API functions).
Table B–3 Routine Errors
Error
Value in Field
Meaning
GSS_S_BAD_MECH
1
An unsupported mechanism was requested
GSS_S_BAD_NAME
2
An invalid name was supplied
GSS_S_BAD_NAMETYPE
3
A supplied name was of an unsupported type
GSS_S_BAD_BINDINGS
4
Incorrect channel bindings were supplied
GSS_S_BAD_STATUS
5
An invalid status code was supplied
GSS_S_BAD_MIC, GSS_S_BAD_SIG
6
A token had an invalid MIC
GSS_S_NO_CRED
7
No credentials were supplied, or the credentials were unavailable or inaccessible
GSS_S_NO_CONTEXT
8
No context has been established
GSS_S_DEFECTIVE_TOKEN
9
A token was invalid
GSS_S_DEFECTIVE_CREDENTIAL
10
A credential was invalid
GSS_S_CREDENTIALS_EXPIRED
11
The referenced credentials have expired
GSS_S_CONTEXT_EXPIRED
12
The context has expired
GSS_S_FAILURE
13
Miscellaneous failure. The underlying mechanism detected an error for which no specific GSS–API status code is defined. The mechanism-specific status code (minor-status code) provides more details about the error.
GSS_S_BAD_QOP
14
The quality-of-protection requested could not be provided
GSS_S_UNAUTHORIZED
15
The operation is forbidden by local security policy
GSS_S_UNAVAILABLE
16
The operation or option is unavailable
GSS_S_DUPLICATE_ELEMENT
17
The requested credential element already exists
GSS_S_NAME_NOT_MN
18
The provided name was not a Mechanism Name (MN)
The routine documentation also uses the name GSS_S_COMPLETE, which is a zero value, to indicate an absence of any API errors or supplementary information bits.
The following table lists the supplementary information values returned by GSS-API functions.
Table B–4 Supplementary Information Codes
Code
Bit Number
Meaning
GSS_S_CONTINUE_NEEDED
0 (LSB)
Returned only by gss_init_sec_context() or gss_accept_sec_context(). The routine must be called again to complete its function
GSS_S_DUPLICATE_TOKEN
1
The token was a duplicate of an earlier token
GSS_S_OLD_TOKEN
2
The token's validity period has expired
GSS_S_UNSEQ_TOKEN
3
A later token has already been processed
GSS_S_GAP_TOKEN
4
An expected per-message token was not received
For more on status codes, see Status Codes.
Displaying Status Codes
The function gss_display_status() translates GSS-API status codes into text format, allowing them to be displayed to a user or put in a text log. Because gss_display_status() only displays one status code at a time, and some functions can return multiple status conditions, it should be invoked as part of a loop. As long as gss_display_status() indicates a non-zero status code (in Example B–1, the value returned in the message_context parameter), another status code is available for the function to fetch.
Example B–1 Displaying Status Codes with gss_display_status()
OM_uint32 message_context;
OM_uint32 status_code;
OM_uint32 maj_status;
OM_uint32 min_status;
gss_buffer_desc status_string;
message_context = 0;
do {
     maj_status = gss_display_status(
               &min_status,
               status_code,
               GSS_C_GSS_CODE,
               GSS_C_NO_OID,
               &message_context,
               &status_string);
     fprintf(stderr, "%.*s\n", \
               (int)status_string.length, \
               (char *)status_string.value);
     gss_release_buffer(&min_status, &status_string,);
} while (message_context != 0);
Status Code Macros
The macros GSS_CALLING_ERROR(), GSS_ROUTINE_ERROR() and GSS_SUPPLEMENTARY_INFO() are provided, each of which takes a GSS status code and removes all but the relevant field. For example, the value obtained by applying GSS_ROUTINE_ERROR() to a status code removes the calling errors and supplementary information fields, leaving only the routine errors field. The values delivered by these macros can be directly compared with a GSS_S_xxx symbol of the appropriate type. The macro GSS_ERROR() is also provided, which when applied to a GSS–API status code returns a non-zero value if the status code indicated a calling or routine error, and a zero value otherwise. All macros defined by the GSS-API evaluate their argument(s) exactly once.
