GSS-API Programming Guide
GSS-API Data Types and Values
This section covers various types of GSS-API data types and values. Certain data types that are opaque to the user, such as gss_cred_id_t or gss_name_t, are not covered here, since there is no advantage to knowing their structure. This section explains the following:
Basic GSS-API Data Types
These are some of the data types used by the GSS-API.
OM_uint32
The OM_uint32 is a platform-independent 32–bit unsigned integer.
gss_buffer_desc
This is the definition of the gss_buffer_desc and the gss_buffer_t pointer:
typedef struct gss_buffer_desc_struct {
        size_t length;
        void *value;
} gss_buffer_desc, *gss_buffer_t;
gss_OID_desc
This is the definition of the gss_OID_desc and the gss_OID pointer:
typedef struct gss_OID_desc_struct {
        OM_uint32 length;
        void*elements;
} gss_OID_desc, *gss_OID;
gss_OID_set_desc
This is the definition of the gss_OID_set_desc and the gss_OID_set pointer:
typedef struct gss_OID_set_desc_struct  {
        size_t  count;
        gss_OID elements;
} gss_OID_set_desc, *gss_OID_set;
gss_channel_bindings_struct
This is the definition of the gss_channel_bindings_struct structure and the gss_channel_bindings_t pointer:
typedef struct gss_channel_bindings_struct {
        OM_uint32 initiator_addrtype;
        gss_buffer_desc initiator_address;
        OM_uint32 acceptor_addrtype;
        gss_buffer_desc acceptor_address;
        gss_buffer_desc application_data;
} *gss_channel_bindings_t;
Name Types
A name type indicates the format of the name with which it is associated. (See Names and OIDs for more on names and name types.) The GSS-API supports the following name types, which are all gss_OID types:
Table B–5 Name Types
Name Type
Meaning
GSS_C_NO_NAME
The recommended symbolic name GSS_C_NO_NAME indicates that no name is being passed within a particular value of a parameter used for the purpose of transferring names.
GSS_C_NO_OID
This value corresponds to a null input value instead of an actual object identifier. Where specified, it indicates interpretation of an associated name based on a mechanism-specific default printable syntax.
GSS_C_NT_ANONYMOUS
Provided as a means to identify anonymous names, and can be compared against in order to determine, in a mechanism-independent fashion, whether a name refers to an anonymous principal.
GSS_C_NT_EXPORT_NAME
A name that has been exported with the gss_export_name() function.
GSS_C_NT_HOSTBASED_SERVICE
This name type is used to represent services associated with host computers. This name form is constructed using two elements, "service" and "hostname,” as follows: service@hostname.
GSS_C_NT_MACHINE_UID_NAME
This name type is used to indicate a numeric user identifier corresponding to a user on a local system. Its interpretation is OS-specific. The gss_import_name() function resolves this UID into a username, which is then treated as the User Name Form.
GSS_C_NT_STRING_STRING_UID_NAME
This name type is used to indicate a string of digits representing the numeric user identifier of a user on a local system. Its interpretation is OS-specific. This name type is similar to the Machine UID Form, except that the buffer contains a string representing the user ID.
GSS_C_NT_USER_NAME
A named user on a local system. Its interpretation is OS-specific. It takes the form: username.
Address Types for Channel Bindings
Table B–6 shows the possible values for the initiator_addrtype and acceptor_addrtype fields of the gss_channel_bindings_struct structure. These fields indicate the format that a name can take (for example, ARPAnet IMP address format or AppleTalk address format). Channel bindings are discussed in Channel Bindings.
Table B–6 Channel Binding Address Types
Field
Value (Decimal)
Address Type
GSS_C_AF_UNSPEC
Unspecified address type
GSS_C_AF_LOCAL
Host-local
GSS_C_AF_INET
Internet address type (example: IP)
GSS_C_AF_IMPLINK
ARPAnet IMP
GSS_C_AF_PUP
pup protocols (example: BSP)
GSS_C_AF_CHAOS
MIT CHAOS protocol
GSS_C_AF_NS
XEROX NS
GSS_C_AF_NBS
nbs
GSS_C_AF_ECMA
ECMA
GSS_C_AF_DATAKIT
datakit protocols
GSS_C_AF_CCITT
10
CCITT
GSS_C_AF_SNA
11
IBM SNA
GSS_C_AF_DECnet
12
DECnet
GSS_C_AF_DLI
13
Direct data link interface
GSS_C_AF_LAT
14
LAT
GSS_C_AF_HYLINK
15
NSC Hyperchannel
GSS_C_AF_APPLETALK
16
AppleTalk
GSS_C_AF_BSC
17
BISYNC
GSS_C_AF_DSS
18
Distributed system services
GSS_C_AF_OSI
19
OSI TP4
GSS_C_AF_X25
21
X.25
GSS_C_AF_NULLADDR
255
No address specified
