GSS-API Programming Guide
Unwrapping the Message
After accepting the context, the server receives the message sent by the client. Because the GSS-API doesn't provide a function to do this, the program uses its own function, recv_token():
if (recv_token(s, &xmit_buf) < 0)
     return(-1);
Since the message might be encrypted, the program uses the GSS-API function gss_unwrap() to unwrap it:
maj_stat = gss_unwrap(&min_stat, context, &xmit_buf, &msg_buf,
                           &conf_state, (gss_qop_t *) NULL);
     if (maj_stat != GSS_S_COMPLETE) {
        display_status("unwrapping message", maj_stat, min_stat);
        return(-1);
     } else if (! conf_state) {
        fprintf(stderr, "Warning!  Message not encrypted.\n");
     (void) gss_release_buffer(&min_stat, &xmit_buf);
gss_unwrap() takes the message that recv_token() has placed in xmit_buf, translates it, and puts the result in msg_buf. Two arguments to gss_unwrap() are noteworthy: conf_state is a flag to indicate whether confidentiality was applied for this message (that is, if the data is encrypted or not), and the final NULL indicates that the program isn't interested in the QOP used to protect the message.
