Because establishing a context can involve a series of token exchanges between the client and the server, both context acceptance and context initialization should be performed in loops, to maintain program portability. Indeed, the loop for accepting a context is very similar to that for establishing one, although rather in reverse. (Compare with Establishing a Context.)
The first thing the server does is look for a token that the client should have sent as part of the context initialization process. Remember, the GSS-API does not send or receive tokens itself, so programs must have their own routines for performing these tasks. The one the server uses for receiving the token is called recv_token() (it can be found at recv_token()):
do {
if (recv_token(s, &recv_tok) < 0)
return -1;
Next, the program calls the GSS-API function gss_accept_sec_context():
maj_stat = gss_accept_sec_context(&min_stat,
context,
server_creds,
&recv_tok,
GSS_C_NO_CHANNEL_BINDINGS,
&client,
&doid,
&send_tok,
ret_flags,
NULL, /* ignore time_rec */
NULL); /* ignore del_cred_handle */
where
min_stat is the error status returned by the underlying mechanism.
context is the context being established.
server_creds is the credential for the service being provided (see Acquiring Credentials).
recv_tok is the token received from the client by recv_token().
GSS_C_NO_CHANNEL_BINDINGS is a flag indicating not to use channel bindings (see Channel Bindings).
client is the ASCII name of the client.
oid is the mechanism (in OID format).
send_tok is the token to send to the client.
ret_flags are various flags indicating whether the context supports a given option, such as message-sequence-detection.
NULL and NULL indicate that the program is not interested in the length of time the context will be valid, nor in whether the server can act as a client's proxy.
The acceptance loop continues (barring an error) as long as gss_accept_sec_context() sets maj_stat to GSS_S_CONTINUE_NEEDED. If maj_stat is not equal to either that value nor to GSS_S_COMPLETE, there's a problem and the loop exits.
gss_accept_sec_context() returns a positive value for the length of send_tok if there is a token to send back to the client. The next step is to see if there's a token to send, and, if so, to send it:
if (send_tok.length != 0) {
if (send_token(s, &send_tok) < 0) {
fprintf(log, "failure sending token\n");
return -1;
(void) gss_release_buffer(&min_stat, &send_tok);
