The format of messages from the SAC is defined by the structure sacmsg:
struct sacmsg {
int sc_size; /* size of optional data portion */
char sc_type; /* type of message */
The SAC can send four types of messages to port monitors. The type of message is indicated by setting the sc_type field of the sacmsg structure to one of the following:
SC_STATUS status request.
SC_ENABLE enable message.
SC_DISABLE disable message.
SC_READDB message indicating that the port monitor's _pmtab file should be read.
sc_size indicates the size of the optional data part of the message. See Message Classes. For the Solaris environment, sc_size should always be set to 0.
A port monitor must respond to every message sent by the SAC.
