XDR unions are discriminated unions, and do not look like C unions. They are more similar to Pascal variant records.
union-definition:
"union" union-ident "switch" "("simple declaration")" "{"
case-list
case-list:
"case" value ":" declaration ";"
"case" value ":" declaration ";" case-list
"default" ":" declaration ";"
The following example is of a type returned as the result of a “read data” operation: if no error occurs, return a block of data. Otherwise, don't return anything.
union read_result switch (int errno) {
case 0:
opaque data[1024];
default:
void;
This union compiles into the following:
struct read_result {
int errno;
union {
char data[1024];
} read_result_u;
typedef struct read_result read_result;
Notice that the union component of the output struct
has the same name as the type name, except for the trailing _u.
