You declare RPC programs using the following syntax:
program-definition:
"program" program-ident "{"
version-list
"}" "=" value;
version-list:
version ";"
version ";" version-list
version:
"version" version-ident "{"
procedure-list
"}" "=" value;
procedure-list:
procedure ";"
procedure ";" procedure-list
procedure:
type-ident procedure-ident "(" type-ident ")" "=" value;
When the -N option is specified, rpcgen also recognizes the following syntax.
procedure:
type-ident procedure-ident "(" type-ident-list ")" "=" value;
type-ident-list:
type-ident
type-ident "," type-ident-list
Example:
* time.x: Get or set the time. Time is represented as seconds
* since 0:00, January 1, 1970.
program TIMEPROG {
version TIMEVERS {
unsigned int TIMEGET(void) = 1;
void TIMESET(unsigned) = 2;
} = 1;
} = 0x20000044;
Note that the void argument type means that no argument is passed.
The following file compiles into these #define statements in the output header file.
#define TIMEPROG 0x20000044 #define TIMEVERS 1 #define TIMEGET 1 #define TIMESET 2
