Several exceptions to the RPC language rules follow.
The features of the C-style mode of rpcgen have implications for the passing of void arguments. No arguments need be passed if their value is void.
C has no built-in Boolean type. However, the RPC library uses a Boolean
type called bool_t that is either TRUE or FALSE. Parameters declared as type bool in XDR language
are compiled into bool_t in the output header file.
Example:
bool married; --> bool_t married;
The C language has no built-in string type, but instead uses the null-terminated char * convention. In C, strings are usually treated as null-terminated
single-dimensional arrays.
In XDR language, strings are declared using the string
keyword, and compiled into type char * in the output header file.
The maximum size contained in the angle brackets specifies the maximum number
of characters allowed in the strings, not counting the NULL
character. You can omit the maximum size, indicating a string of arbitrary
length.
Examples:
string name<32>; --> char *name; string longname<>; --> char *longname;
NULL strings cannot be passed; however, a zero-length string (that is, just the terminator or NULL byte) can be passed.
Opaque data is used in XDR to describe untyped data, that is, sequences of arbitrary bytes. You can declare opaque data either as a fixed-length or variable-length array.
opaque diskblock[512]; --> char diskblock[512];
opaque filedata<1024>; --> struct {
u_int filedata_len;
char *filedata_val;
} filedata;
In a void declaration, the variable is not named. The declaration is just void and nothing else. Void declarations can only occur in two places: union definitions and program definitions as the argument or result of a remote procedure; for example, no arguments are passed.
