System Administration Guide: Naming and Directory Services (FNS and NIS+)
Removing NIS+ That Was Installed Using nisclient
To remove NIS+ from a client machine that was set up as an NIS+ client using the nisclient -i script as described in Chapter 4, Configuring NIS+ With Scripts, run nisclient with the -r option:
client# nisclient -r
nisclient -r simply undoes the most recent iteration of nisclient -i; it restores the previous naming system used by the client, such as NIS or /etc files.
