System Administration Guide: Naming and Directory Services (FNS and NIS+)
Files Considerations
When using fncreate with the -t org option to create your FNS namespace, the command must be executed by superuser on the machine that owns the file system on which /var is located. The files used by FNS are stored in the /var/fn directory.
Once users' contexts are created, users are allowed to modify their own contexts based on their UNIX credentials.
If exported, the file system /var/fn can be mounted by other systems to access the FNS namespace.
