System Administration Guide: Naming and Directory Services (FNS and NIS+)
NIS Considerations
The fncreate command must be executed by superuser on the NIS system that will serve as the NIS master server for the FNS maps.
The NIS maps used by FNS are stored in /var/yp/domainname.
Any changes to the FNS information can only be done by the superuser on the FNS NIS master server using FNS commands.
