When your primary enterprise-level naming service is NIS+, take into account the following points.
The command syntax shown above creates the FNS namespace for the root NIS+ domain. To specify a domain other than the root, add the domain name between the double slashes, as in:
# fncreate -t org org/sales.doc.com./ |
Note the trailing dot after the fully qualified sales.doc.com. domain name.
The fncreate commands creates NIS+ tables and directories in the ctx_dir directory. The ctx_dir directory object resides at the same level as the NIS+ groups_dir and org_dir directory objects of the domain.
With a large domain, the additional space required on the NIS+ server could be substantial and in a large installation performance might be improved by using separate servers for FNS and the standard NIS+ tables. See for information on how to use separate servers for FNS and NIS+.
In a large, or mission-critical domain, FNS service should be replicated. See Replicating FNS Servicefor information on how to replicate FNS service.
The user who runs fncreate and other FNS commands is expected to have the necessary NIS+ credentials.
The environment variable NIS_GROUP
specifies the group owner for the NIS+ objects created by fncreate. In order to facilitate administration of the NIS+ objects, NIS_GROUP
should be set to the name of the
NIS+ group responsible for FNS administration for that domain prior to executing fncreate and other FNS commands.
Changes to NIS+ related properties, including default access control rights, could be effected using NIS+ administration tools and interfaces after the context has been created. The NIS+ object name that corresponds to an FNS composite name can be obtained using fnlookup and fnlist, described later in this document.
