Solaris ボリュームマネージャの管理
例 - すべての状態データベースの複製の状態をチェックする
# metadb -i
        flags           first blk       block count
     a m  p  luo        16              8192            /dev/dsk/c0t0d0s7
     a    p  luo        8208            8192            /dev/dsk/c0t0d0s7
     a    p  luo        16400           8192            /dev/dsk/c0t0d0s7
     a    p  luo        16              8192            /dev/dsk/c1t3d0s1
      W   p  l          16              8192            /dev/dsk/c2t3d0s1
     a    p  luo        16              8192            /dev/dsk/c1t1d0s3
     a    p  luo        8208            8192            /dev/dsk/c1t1d0s3
     a    p  luo        16400           8192            /dev/dsk/c1t1d0s3
 r - replica does not have device relocation information
 o - replica active prior to last mddb configuration change
 u - replica is up to date
 l - locator for this replica was read successfully
 c - replica's location was in /etc/lvm/mddb.cf
 p - replica's location was patched in kernel
 m - replica is master, this is replica selected as input
 W - replica has device write errors
 a - replica is active, commits are occurring to this replica
 M - replica had problem with master blocks
 D - replica had problem with data blocks
 F - replica had format problems
 S - replica is too small to hold current data base
 R - replica had device read errors
状態表示の後にすべてのフラグの説明が表示されます。デバイス名の前の文字はデバイスの状態を示します。 大文字は障害状態を、小文字は「Okay」状態を示します。
