Solaris ボリュームマネージャの管理
例 - ディスク上のエクステントヘッダーからソフトパーティションを復元する
# metarecover c1t1d0s1 -p -d
The following soft partitions were found and will be added to
your metadevice configuration.
 Name            Size     No. of Extents
    d10           10240         1
    d11           10240         1
    d12           10240         1
    d10           10240         1
    d11           10240         1
    d12           10240         1
WARNING: You are about to add one or more soft partition
metadevices to your metadevice configuration.  If there
appears to be an error in the soft partition(s) displayed
above, do NOT proceed with this recovery operation.
Are you sure you want to do this (yes/no)?yes
c1t1d0s1: Soft Partitions recovered from device.
bash-2.05# metastat
d10: Soft Partition
    Device: c1t1d0s1
    State: Okay
        Device              Start Block  Dbase Reloc
        c1t1d0s1                   0     No    Yes
        Extent              Start Block              Block count
             0                        1                    10240
d11: Soft Partition
    Device: c1t1d0s1
    State: Okay
        c1t1d0s1                   0     No    Yes
             0                    10242                    10240
d12: Soft Partition
    Device: c1t1d0s1
    State: Okay
        c1t1d0s1                   0     No    Yes
             0                    20483                    10240
この例では、すべての状態データベースの複製が誤って削除されているときに、ディスクから 3 つのソフトパーティションを復元します。
