Solaris ボリュームマネージャの管理
例 - Solaris ボリュームマネージャのボリューム構成を表示する
metastat コマンドの出力例を以下に示します。
# metastat
d50: RAID
    State: Okay
    Interlace: 32 blocks
Original device:
        Device              Start Block  Dbase State        Reloc  Hot Spare
        c1t4d0s5                 330     No    Okay         Yes
        c1t5d0s5                 330     No    Okay         Yes
        c2t4d0s5                 330     No    Okay         Yes
        c2t5d0s5                 330     No    Okay         Yes
        c1t1d0s5                 330     No    Okay         Yes
        c2t1d0s5                 330     No    Okay         Yes
d1: Concat/Stripe
    Stripe 0:
        Device              Start Block  Dbase  Reloc
        c1t2d0s3                   0     No     Yes
d2: Concat/Stripe
    Stripe 0:
        c2t2d0s3                   0     No     Yes
d80: Soft Partition
    Device: d70
    State: Okay
        Extent              Start Block              Block count
             0                        1                  2097152
d81: Soft Partition
    Device: d70
    State: Okay
             0                  2097154                  2097152
d70: Mirror
    Submirror 0: d71
      State: Okay
    Submirror 1: d72
      State: Okay
    Pass: 1
    Read option: roundrobin (default)
    Write option: parallel (default)
d71: Submirror of d70
    State: Okay
    Stripe 0:
        c1t3d0s3                   0     No    Okay         Yes
    Stripe 1:
        c1t3d0s4                   0     No    Okay         Yes
    Stripe 2:
        c1t3d0s5                   0     No    Okay         Yes
d72: Submirror of d70
    State: Okay
    Stripe 0:
        c2t3d0s3                   0     No    Okay         Yes
    Stripe 1:
        c2t3d0s4                   0     No    Okay         Yes
    Stripe 2:
        c2t3d0s5                   0     No    Okay         Yes
hsp010: is empty
hsp014: 2 hot spares
        Device              Status      Length          Reloc
        c1t2d0s1            Available    617652 blocks  Yes
        c2t2d0s1            Available    617652 blocks  Yes
hsp050: 2 hot spares
        c1t2d0s5            Available    4197879 blocks Yes
        c2t2d0s5            Available    4197879 blocks Yes
hsp070: 2 hot spares
        c1t2d0s4            Available    4197879 blocks Yes
        c2t2d0s4            Available    4197879 blocks Yes
Device Relocation Information:
Device              Reloc       Device ID
c1t2d0              Yes         id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0N1S200002103AF29
c2t2d0              Yes         id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0P64Z00002105Q6J7
c1t1d0              Yes         id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0N1EM00002104NP2J
c2t1d0              Yes         id1,sd@SSEAGATE_ST39204LCSUN9.0G3BV0N93J000071040L3S
c0t0d0              Yes         id1,dad@s53554e575f4154415f5f53543339313430412525415933
