Solaris のシステム管理 (基本編)
IA: 例 - Solaris fdisk パーティションと、DOSBIG fdisk パーティションを作成する
次の例は、Solaris fdisk パーティションと DOSBIG fdisk パーティションを作成する方法を説明しています。
format> fdisk
The recommended default partitioning for your disk is:
   a 100% "SOLARIS System" partition.
To select this, please type "y".  To partition your disk
differently, type "n" and the "fdisk" program will let you
select other partitions. n
             Total disk size is 2694 cylinders
             Cylinder size is 765 (512 byte) blocks
                                         Cylinders
    Partition   Status    Type      Start   End   Length    %
THERE ARE NO PARTITIONS CURRENTLY DEFINED SELECT ONE OF THE FOLLOWING:
     1.   Create a partition
     2.   Change Active (Boot from) partition
     3.   Delete a partition
     4.   Exit (Update disk configuration and exit)
     5.   Cancel (Exit without updating disk configuration)
Enter Selection: 1
Indicate the type of partition you want to create
  (1=SOLARIS, 2=UNIX, 3=PCIXOS, 4=Other, 8=DOSBIG)
  (5=DOS12, 6=DOS16, 7=DOSEXT, 0=Exit) ?8
Indicate the percentage of the disk you want this partition
to use (or enter "c" to specify in cylinders). 20
Do you want this to become the Active partition? If so, it will be
activated each time you reset your computer or when you turn it on
again. Please type "y" or "n". n
                                        Cylinders
        1                 DOS-BIG       1   538     538     20
     5.   Cancel (Exit without updating disk configuration)Enter
Selection: 1
  (5=DOS12, 6=DOS16, 7=DOSEXT, 0=Exit) ?1
to use (or enter "c" to specify in cylinders). 80
again. Please type "y" or "n". y
Partition 2 is now the Active partition Total disk size is 2694
cylinders
                                         Cylinders
        2       Active    SOLARIS     539  2693    2155     80
Enter Selection: 4
format> q
