IPQoS Administration Guide
How to Ensure That the IPQoS Configuration Is Applied After Each Reboot
You must explicitly make an IPQoS configuration persistent across reboots. Otherwise, the current configuration applies only until the system reboots. When IPQoS works correctly on a system, do the following to make the configuration persistent across reboots.
  1. Log in as superuser to the IPQoS-enabled system.
  2. Test for the existence of an IPQoS configuration in the kernel modules:
    # ipqosconf -l
    If a configuration already exists, ipqosconf displays it on the screen. If you do not receive output, apply the configuration, as explained inHow to Apply a New Configuration to the IPQoS Kernel Modules.
  3. Ensure that the existing IPQoS configuration is applied every time the IPQoS system reboots.
    # /usr/sbin/ipqosconf -c
    The -c option causes the current IPQoS configuration to be represented in the boot-time configuration file /etc/inet/ipqosinit.conf.
