This section introduces a simple network scenario that shows how to implement IPQoS on systems with VLAN devices. The scenario includes two IPQoS systems, machine1 and machine2, that are connected by a switch. The VLAN device on machine1 has the IP address 10.10.8.1. The VLAN device on machine2 has the IP address 10.10.8.3.
The following IPQoS configuration file for machine1 shows a simple solution for marking traffic through the switch to machine2.
fmt_version 1.0
action {
module ipgpc
name ipgpc.classify
filter {
name myfilter2
daddr 10.10.8.3
class myclass
class {
name myclass
next_action mark4
action {
name mark4
module dlcosmk
params {
cos 4
next_action continue
global_stats true
In this configuration, all traffic from machine1 that is destined for the VLAN device on machine2 is passed to the dlcosmk marker. The mark4 marker action instructs dlcosmk to add a VLAN mark to datagrams of class myclass with a CoS of 4. The 4 user priority value indicates that the switch between the two machines should give controlled load forwarding to myclass traffic flows from machine1.
