flowacct gathers information about flows in a flow table that is composed of flow records. Each entry in the table contains one flow record. You cannot display a flow-account table.
In the IPQoS configuration file, you define the following flowacct parameters to measure flow records and to write them to the table:
timer – Defines an interval, in milliseconds, when timed-out flows are removed from the flow table and written to the file that is created by acctadm
timeout – Defines a interval, in milliseconds, that specifies how long a packet flow must be inactive before it times out
You can configure timer and timeout to have different values.
max_limit – Places an upper limit on the number of flow records that can be stored in the table
