# metastat d4
d4: RAID
State: Okay
Hot spare pool: hsp001
# metaparam -h none d4
# metastat d4
d4: RAID
State: Okay
Hot spare pool:
In this example, the hot spare pool hsp001 is initially associated with a RAID 5 volume named d4. The hot spare pool association is changed to none, which indicates that no hot spare pool should be associated with this device. The metastat command shows the hot spare pool association before and after this change.
