# metarecover c1t1d0s1 -p -d
The following soft partitions were found and will be added to
your metadevice configuration.
Name Size No. of Extents
d10 10240 1
d11 10240 1
d12 10240 1
d10 10240 1
d11 10240 1
d12 10240 1
WARNING: You are about to add one or more soft partition
metadevices to your metadevice configuration. If there
appears to be an error in the soft partition(s) displayed
above, do NOT proceed with this recovery operation.
Are you sure you want to do this (yes/no)?yes
c1t1d0s1: Soft Partitions recovered from device.
bash-2.05# metastat
d10: Soft Partition
Device: c1t1d0s1
State: Okay
Device Start Block Dbase Reloc
c1t1d0s1 0 No Yes
Extent Start Block Block count
0 1 10240
d11: Soft Partition
Device: c1t1d0s1
State: Okay
c1t1d0s1 0 No Yes
0 10242 10240
d12: Soft Partition
Device: c1t1d0s1
State: Okay
c1t1d0s1 0 No Yes
0 20483 10240
This example recovers three soft partitions from disk, after the state database replicas were accidentally deleted.
