Task |
Description |
For Instructions |
Graphically administer your volume management configuration |
Use the Solaris Management Console to administer your volume management configuration. |
Online help from within Solaris Volume Manager (Enhanced Storage) node of the Solaris Management Console application |
Graphically administer slices and file systems |
Use the Solaris Management Console graphical user interface to administer your disks and file systems, performing such tasks as partitioning disks and constructing UFS file systems. |
Online help from within the Solaris Management Console application |
Optimize Solaris Volume Manager |
Solaris Volume Manager performance is dependent on a well-designed configuration. Once created, the configuration needs monitoring and tuning. | ||
Plan for future expansion |
Because file systems tend to run out of space, you can plan for future growth by putting a file system into a concatenation. | ||
