Attach the disk or disks that contain the Solaris Volume Manager configuration to a system with no preexisting Solaris Volume Manager configuration.
Do a reconfiguration reboot to ensure that the system recognizes the newly added disks.
# reboot -- -r |
Determine the major/minor number for a slice containing a state database replica on the newly added disks.
Use ls -lL, and note the two numbers between the group name and the date. Those are the major/minor numbers for this slice.
# ls -Ll /dev/dsk/c1t9d0s7 brw-r----- 1 root sys 32, 71 Dec 5 10:05 /dev/dsk/c1t9d0s7 |
If necessary, determine the major name corresponding with the major number by looking up the major number in /etc/name_to_major.
# grep " 32" /etc/name_to_major sd 32 |
Update the /kernel/drv/md.conf file with two commands: one command to tell Solaris Volume Manager where to find a valid state database replica on the new disks, and one command to tell it to trust the new replica and ignore any conflicting device ID information on the system.
In the line in this example that begins with mddb_bootlist1, replace the sd in the example with the major name you found in the previous step. Replace 71 in the example with the minor number you identified in Step 3.
#pragma ident "@(#)md.conf 2.1 00/07/07 SMI" # # Copyright (c) 1992-1999 by Sun Microsystems, Inc. # All rights reserved. # name="md" parent="pseudo" nmd=128 md_nsets=4; # #pragma ident "@(#)md.conf 2.1 00/07/07 SMI" # # Copyright (c) 1992-1999 by Sun Microsystems, Inc. # All rights reserved. # name="md" parent="pseudo" nmd=128 md_nsets=4; # Begin MDD database info (do not edit) mddb_bootlist1=" |
Reboot to force Solaris Volume Manager to reload your configuration.
You will see messages similar to the following displayed to the console.
volume management starting. Dec 5 10:11:53 lexicon metadevadm: Disk movement detected Dec 5 10:11:53 lexicon metadevadm: Updating device names in Solaris Volume Manager The system is ready. |
Verify your configuration by using the metadb and metastat commands.
# metadb
flags first blk block count
a m p luo 16 8192 /dev/dsk/c1t9d0s7
a luo 16 8192 /dev/dsk/c1t10d0s7
a luo 16 8192 /dev/dsk/c1t11d0s7
a luo 16 8192 /dev/dsk/c1t12d0s7
a luo 16 8192 /dev/dsk/c1t13d0s7
# metastat
d12: RAID
State: Okay
Interlace: 32 blocks
Original device:
Device Start Block Dbase State Reloc Hot Spare
c1t11d0s3 330 No Okay Yes
c1t12d0s3 330 No Okay Yes
c1t13d0s3 330 No Okay Yes
d20: Soft Partition
Device: d10
State: Okay
Extent Start Block Block count
0 3592 8192
d21: Soft Partition
Device: d10
State: Okay
0 11785 8192
d22: Soft Partition
Device: d10
State: Okay
0 19978 8192
d10: Mirror
Submirror 0: d0
State: Okay
Submirror 1: d1
State: Okay
Pass: 1
Read option: roundrobin (default)
Write option: parallel (default)
d0: Submirror of d10
State: Okay
Stripe 0: (interlace: 32 blocks)
c1t9d0s0 0 No Okay Yes
c1t10d0s0 3591 No Okay Yes
d1: Submirror of d10
State: Okay
c1t9d0s1 0 No Okay Yes
c1t10d0s1 0 No Okay Yes
Device Relocation Information:
Device Reloc Device ID
c1t9d0 Yes id1,sd@SSEAGATE_ST39103LCSUN9.0GLS3487980000U00907AZ
c1t10d0 Yes id1,sd@SSEAGATE_ST39103LCSUN9.0GLS3397070000W0090A8Q
c1t11d0 Yes id1,sd@SSEAGATE_ST39103LCSUN9.0GLS3449660000U00904NZ
c1t12d0 Yes id1,sd@SSEAGATE_ST39103LCSUN9.0GLS32655400007010H04J
c1t13d0 Yes id1,sd@SSEAGATE_ST39103LCSUN9.0GLS3461190000701001T0
# metadb
# metastat
d12: RAID
State: Okay
Original device:
d20: Soft Partition
Device: d10
State: Okay
0 3592 8192
d21: Soft Partition
Device: d10
State: Okay
0 11785 8192
d22: Soft Partition
Device: d10
State: Okay
0 19978 8192
d10: Mirror
Submirror 0: d0
State: Okay
Submirror 1: d1
State: Okay
Pass: 1
State: Okay
State: Okay
c1t9d0 Yes id1,sd@SSEAGATE_ST39103LCSUN9.0GLS3487980000U00907AZ1
# metastat -p
d12 -r c1t11d0s3 c1t12d0s3 c1t13d0s3 -k -i 32b
d20 -p d10 -o 3592 -b 8192
d21 -p d10 -o 11785 -b 8192
d22 -p d10 -o 19978 -b 8192
d10 -m d0 d1 1
d0 1 2 c1t9d0s0 c1t10d0s0 -i 32b
d1 1 2 c1t9d0s1 c1t10d0s1 -i 32b
