You can mount NFS file system resources by using a client-side service called automounting (or AutoFS), which enables a system to automatically mount and unmount NFS resources whenever you access them. The resource remains mounted as long as you remain in the directory and are using a file. If the resource is not accessed for a certain period of time, it is automatically unmounted.
AutoFS provides the following features:
NFS resources don't need to be mounted when the system boots, which saves booting time.
Users don't need to know the root password to mount and unmount NFS resources.
Network traffic might be reduced, since NFS resources are only mounted when they are in use.
The AutoFS service is initialized by the automount utility, which runs automatically when a system is booted. The automountd daemon runs continuously and is responsible for the mounting and unmounting of the NFS file systems on an as-needed basis. By default, the /home file system is is mounted by the automount daemon.
With AutoFS, you can specify multiple servers to provide the same file system. This way, if one of the servers is down, AutoFS can try to mount from another machine.
For complete information on how to set up and administer AutoFS, see System Administration Guide: IP Services.
