NFS is a distributed file system service that can be used to share resources (files or directories) from one system, typically a server, with other systems on the network. For example, you might want to share third-party applications or source files with users on other systems.
NFS makes the actual physical location of the resource irrelevant to the user. Instead of placing copies of commonly used files on every system, NFS allows you to place one copy on one system's disk and let all other systems access it from the network. Under NFS, remote files are virtually indistinguishable from local ones.
A system becomes an NFS server if it has resources to share on the network. A server keeps a list of currently shared resources and their access restrictions (such as read/write or read-only access).
When you share a resource, you make it available for mounting by remote systems.
You can share a resource in these ways:
By adding an entry to the /etc/dfs/dfstab (distributed file system table) file and rebooting the system
For information on how to share resources, see Chapter 39, Mounting and Unmounting File Systems (Tasks). For a complete description of NFS, see “Managing Network File Systems (Overview)” in System Administration Guide: Resource Management and Network Services.
