This task describes how to limit read access to the password-related columns of the passwd table to the entry owner and the table administrators, without affecting the read access of other authenticated principals (including applications) to the remaining columns of the passwd table.
This task establishes the following rights:
Nobody Owner Group World Table Level Rights: ---- rmcd rmcd ---- Passwd Column Rights: ---- rm-- rmcd ---- Shadow Column Rights: ---- rm-- rmcd ---- |
The domain must not be running in NIS-compatibility mode.
All clients of the domain must have DES credentials.
All clients of the domain must be running Solaris Release 2.3 or a later release.
Users' network passwords (used to encrypt their DES credentials) must be the same directory as their login passwords.
The passwd table must have already been set up. It need not have any information in it, however.
The NIS+ principal performing this task must have modify rights to the passwd table.
All you need is the name of the passwd table.
Task |
Description |
For Instructions, Go To |
Limiting Access to the Passwd Column to Owners and Administrators |
Modify passwd.org_dir, via NIS+ commands, to restrict access to the passwd column for owners and administrators. | ||
Log in to the domain's master server.
The examples in this task use the root master server, rootmaster.
Check the current table and column permissions.
Use the niscat -o command.
rootmaster# niscat -o passwd.org_dir |
This task assumes the existing permissions are:
Access Rights : ----rmcdrmcdr---
Columns :
[0] Name : name
Access Rights : r-----------r---
[1] Name : passwd
Access Rights : -----m----------
[2] Name : uid
[3] Name : gid
[4] Name : gcos
Access Rights : r----m------r---
[5] Name : home
[6] Name : shell
[7] Name : shadow
If your permissions are different, you may need to use a different syntax. For instructions, see Chapter 15, Administering NIS+ Access Rights.
Change the table permissions.
Use the nischmod command to change the table's object-level permissions to ---- rmcdrmcd ----
rootmaster# nischmod og=rmcd,nw= passwd.org_dir |
Change the column permissions.
Use the nistbladm command with the -u option to change the permissions of the passwd and shadow columns to:
passwd ---- rm-- ---- ---- shadow ---- r--- ---- ---- rootmaster# nistbladm -u passwd=o+r, shadow=o+r passwd.org_dir |
Verify the new permissions.
Use the niscat -o command, as you did in Step 2. The permissions should look the same as they do in that step's output.
