Following are summaries of the steps required to populate NIS+ tables. They assume the simplest case, so be sure you are familiar with the more thorough task descriptions before you use this summary as a reference. For brevity, these summaries do not show the server's responses to each command.
Table 9–5 Transferring Files Into NIS+ Tables: Command Summary|
Tasks |
Commands |
Log in to an NIS+ client. |
rootmaster% |
Create working copies of the files to be transferred. |
% cp /etc/hosts /etc/hosts.xfr |
Add /usr/lib/nis to search path. |
% PATH=$PATH:/usr/lib/nis; export PATH |
Transfer each file, one at a time. |
% nisaddent -m -f /etc/hosts.xfr hosts |
Remove old server credentials from publickey file. |
% vi /etc/publickey.xfer |
Transfer it to the cred table. |
% nisaddent -a -f /etc/publickey.xfr cred |
Transfer the automounter files. |
% nisaddent -f auto.master.xfr -t auto_master.org_dir key-value % nisaddent -f auto.home.xfr -t auto_home.org_dir key-value |
Checkpoint the table directory. |
% nisping -C org_dir |
Table 9–6 Transferring Maps Into NIS+ Tables: Command Summary
Tasks |
Commands |
rootmaster% |
Transfer each map, one at a time. |
% nisaddent -m -y olddoc hosts |
Dump |
% makedbm -u /var/yp/olddoc/publickey.byname > /etc/publickey.xfr |
Remove new credentials. |
% vi /etc/publickey.xfr |
Transfer the publickey file. |
% nisaddent -a -f /etc/publickey.xfr -t cred.ortg_dir publickey |
Transfer the automounter maps. |
% nisaddent -y olddoc -Y auto.master -t auto_master.org_dir key-value % nisaddent -y olddoc -Y auto.home -t auto_home.org_dir key-value |
Table 9–7 Transferring NIS+ Tables to NIS Maps: Command Summary
Tasks |
Commands |
Log in to NIS+ server. |
dualserver% |
Transfer NIS+ tables to files. |
% /usr/lib/nis/nisaddent -d [-t table] tabletype > filename |
Transfer files to NIS maps. |
% makedbm flags output-file NIS-dbm-file |
Table 9–8 Limiting Access to Passwd Column: Command Summary
Tasks |
Commands |
Log into the domain's master server. |
rootmaster# |
Check the table's existing rights. |
# niscat -o passwd.org_dir |
Assign the table new rights. |
# nischmod og=rmcd,nw= passwd.org_dir |
Assign the columns new rights |
# nistbladm -u passwd=o+r, shadow=n+r passwd.org_dir |
Verify the new rights. |
