Log in to the domain's master server.
The examples in this task use the root master server, rootmaster.
Check the current table and column permissions.
Use the niscat -o command.
rootmaster# niscat -o passwd.org_dir |
This task assumes the existing permissions are:
Access Rights : ----rmcdrmcdr---
Columns :
[0] Name : name
Access Rights : r-----------r---
[1] Name : passwd
Access Rights : -----m----------
[2] Name : uid
[3] Name : gid
[4] Name : gcos
Access Rights : r----m------r---
[5] Name : home
[6] Name : shell
[7] Name : shadow
If your permissions are different, you may need to use a different syntax. For instructions, see Chapter 15, Administering NIS+ Access Rights.
Change the table permissions.
Use the nischmod command to change the table's object-level permissions to ---- rmcdrmcd ----
rootmaster# nischmod og=rmcd,nw= passwd.org_dir |
Change the column permissions.
Use the nistbladm command with the -u option to change the permissions of the passwd and shadow columns to:
passwd ---- rm-- ---- ---- shadow ---- r--- ---- ---- rootmaster# nistbladm -u passwd=o+r, shadow=o+r passwd.org_dir |
Verify the new permissions.
Use the niscat -o command, as you did in Step 2. The permissions should look the same as they do in that step's output.
