To add two or three aliases to the table, follow these instructions.
Compile a list of each of your mail clients, the locations of their mailboxes, and the names of the mail server systems.
Either be a member of the NIS+ group that owns the table, or become root on the mail server, or assume an equivalent role.
For information about roles, refer to "Using Privileged Applications" in System Administration Guide: Security Services.
(Optional) If necessary, initiate an NIS+ table.
If you are creating a completely new NIS+ mail_aliases table, you must first initiate the table. To complete this task, refer to "Example-Initiating an NIS+ mail_aliases Table".
Add aliases to the table.
See this example of a typical entry.
# aliasadm -a iggy iggy.ignatz@saturn "Iggy Ignatz" |
The following list describes the input from the preceding example.
-a |
The option for adding an alias |
iggy |
The short form of the alias name |
iggy.ignatz@saturn |
The expanded alias name |
"Iggy Ignatz" |
The name for the alias in quotation marks |
Display the entry you created and ensure that it is correct.
# aliasadm -m alias |
alias |
The entry that you created |
For more information, refer to the aliasadm(1M) man page.
