System Administration Guide: Resource Management and Network Services
How to Check the Response of Hosts on the Network
Check the response of hosts on the network with the ping command.
$ ping hostname
If you suspect a physical problem, you can use ping to find the response time of several hosts on the network. If the response from one host is not what you would expect, you can investigate that host. Physical problems could be caused by the following:
For more information about this command, see ping(1M).
Examples-Checking the Response of Hosts on the Network
The simplest version of ping sends a single packet to a host on the network. If ping receives the correct response, it prints the message host is alive.
$ ping elvis
elvis is alive
With the -s option, ping sends one datagram per second to a host. It then prints each response and the time that was required for the round trip. For example:
$ ping -s pluto
64 bytes from pluto (123.456.78.90): icmp_seq=0. time=10. ms
64 bytes from pluto (123.456.78.90): icmp_seq=5. time=0. ms
64 bytes from pluto (123.456.78.90): icmp_seq=6. time=0. ms
^C
----pluto PING Statistics----
8 packets transmitted, 8 packets received, 0% packet loss
round-trip (ms) min/avg/max = 0/2/10
