System Administration Guide: Resource Management and Network Services
How to Send Packets to Hosts on the Network
Test the reliability of your packet sizes with the spray command.
$ spray [ -c count -d interval -l packet_size] hostname
-i count
Number of packets to send.
-d interval
Number of microseconds to pause between sending packets. If you don't use a delay, you might run out of buffers.
-l packet_size
Is the packet size.
hostname
Is the system to send packets.
For more information about this command, see spray(1M).
Example-Sending Packets to Hosts on the Network
The following example sends 100 packets to a host (-c 100) with each packet having a size of 2048 bytes (-l 2048). The packets are sent with a delay time of 20 microseconds between each burst (-d 20).
$ spray -c 100 -d 20 -l 2048 pluto
sending 100 packets of length 2048 to pluto ...
no packets dropped by pluto
279 packets/sec, 573043 bytes/sec
