System Administration Guide: Resource Management and Network Services
How to Access the Performance Tool
The Performance tool is located under System Status in the Navigation pane. To access the Performance tool, do the following:
  1. Click the System Status control entity in the Navigation pane.
    The control entity is used to expand menu items in the Navigation pane.
  2. Click the Performance control entity.
  3. Click the System control entity.
  4. Double-click Summary, Projects, or Users.
    Your choice depends on the usage you want to monitor.
