Values are shown for the following attributes.
Attribute |
Description |
Active Processes |
Number of processes that are active on the system |
Physical Memory Used |
Amount of system memory that is in use |
Physical Memory Free |
Amount of system memory that is available |
Swap Used |
Amount of system swap space that is in use |
Swap Free |
Amount of free system swap space |
Page Rate |
Rate of system paging activity |
System Calls |
Number of system calls per second |
Network Packets |
Number of network packets that are transmitted per second |
CPU Usage |
Percentage of CPU that is currently in use |
Load Average |
Number of processes in the system run queue which are averaged over the last 1, 5, and 15 minutes |
