Use the discover subcommand argument to the -c option of /usr/sbin/poolcfg to create the pools configuration file. The resulting file, /etc/pooladm.conf, contains any existing processor sets.
You can also supply a file name to use instead of the default /etc/pooladm.conf. If the file name is supplied, then the poolcfg commands are applied to the contents of the named file.
For example, to place a discovered configuration in /tmp/foo, do the following:
