How to Create a New Configuration
Use the create subcommand argument to the -c option of /usr/sbin/poolcfg to create a simple
configuration file for a system named tester. Note that
you must quote subcommand arguments that contain white space.
Become superuser.
Type the following:
# poolcfg -c 'create system tester'
View the contents of the configuration file in readable form.
# poolcfg -c info
system tester
int system.version 1
boolean system.bind-default true
string system.comment
