System Administration Guide: Resource Management and Network Services
How to Modify a Configuration
To enhance your simple configuration, create a processor set named batch and a pool named batch. Then join them with an association. Note that you must quote subcommand arguments that contain white space.
  1. Become superuser.
  2. Create processor set batch.
    # poolcfg -c 'create pset batch (uint pset.min = 2; uint pset.max = 10)'
  3. Create pool batch.
    # poolcfg -c 'create pool batch'
  4. Join with an association.
    # poolcfg -c 'associate pool batch (pset batch)'
  5. Display the edited configuration.
    # poolcfg -c info
    system tester
            int system.version 1
            boolean system.bind-default true
            string system.comment
            pool batch
                    boolean pool.default false
                    boolean pool.active true
                    int pool.importance 1
                    string pool.comment
                    pset batch
            pset batch
                    int pset.sys_id -2
                    string pset.units population
                    boolean pset.default true
                    uint pset.max 10
                    uint pset.min 2
                    string pset.comment
                    boolean pset.escapable false
                    uint pset.load 0
                    uint pset.size 0
