System Administration Guide: Security Services
ipc_perm Token
The ipc_perm token contains a copy of the System V IPC access information. This token is added to audit records that are generated by IPC shared-memory events, IPC semaphore events, and IPC message events. The ipc_perm token has eight fields:
The praudit command displays the ipc_perm token as follows:
IPC perm,root,wheel,root,wheel,0,0,0x00000000
The values are taken from the ipc_perm structure that is associated with the IPC object. The following figure shows the format of an ipc_perm token.
Figure 26–17 ipc_perm Token Format
The preceding context describes the graphic.
