System Administration Guide: Security Services
iport Token
The iport token contains the TCP (or UDP) port address. The iport token has two fields:
The praudit command displays the iport token as follows:
ip port,0xf6d6
The following figure shows the format of an iport token.
Figure 26–18 iport Token Format
The preceding context describes the graphic.
