System Administration Guide: Security Services
acl Token
The acl token records information about Access Control Lists. This token consists of four fixed fields. The fixed fields are:
The praudit command displays the acl token as follows:
acl,tpanero,staff,0755
The acl token format is as follows:
Figure 26–4 acl Token Format
The preceding context describes the graphic.
