The arbitrary token encapsulates data for the audit trail. This token consists of four fixed fields and an array of data. The fixed fields are as follows:
a token ID that identifies this token as an arbitrary token
a suggested format field (for example, hexadecimal)
a size field that specifies the size of the data that is encapsulated (for example, short)
a count field that provides the number of following items
The remainder of the token is composed of one or more items of the specified type. The praudit command displays the arbitrary token as follows:
arbitrary,decimal,int,1 42 |
The format of arbitrary token is as follows:
The following table shows the possible values of the print format field. Table 26–6.
Table 26–6 Values for the arbitrary Token's Print Format Field|
Value |
Action |
AUP_BINARY |
Prints the date in binary format |
AUP_OCTAL |
Prints the date in octal format |
AUP_DECIMAL |
Prints the date in decimal format |
AUP_HEX |
Prints the date in hexadecimal format |
AUP_STRING |
Prints the date as a string |
The following table shows the possible values of the item size field.
Table 26–7 Values for the arbitrary Token's Item Size Field|
Value |
Action |
AUR_BYTE |
Data is printed in units of bytes (1 byte) |
AUR_SHORT |
Data is printed in units of shorts (2 bytes) |
AUR_LONG |
Data is printed in units of longs (4 bytes) |
