Solaris Management Console 2.1 software is not compatible with Solaris Management Console 1.0, 1.0.1, or 1.0.2 software. If you want to upgrade to the Solaris 9 9/02 operating environment, and you have Solaris Management Console 1.0, 1.0.1, or 1.0.2 software installed, you must first uninstall the Solaris Management Console software before you upgrade. Solaris Management Console software might exist on your system if you installed the SEAS 2.0 overbox, the SEAS 3.0 overbox, or the Solaris 8 Admin Pack.
Workaround: Choose one of the following workarounds.
Before you upgrade, use the /usr/bin/prodreg command to perform a full uninstall of Solaris Management Console software.
If you did not uninstall Solaris Management Console 1.0, 1.0.1, or 1.0.2 software before you upgraded to the Solaris 9 9/02 operating environment, you must first remove all Solaris Management Console 1.0, 1.0.1, or 1.0.2 packages. Use the pkgrm command for package removal instead of the prodreg command. Carefully follow the order of package removal. Complete the following steps.
Become superuser.
Type the following command.
# pkginfo | grep "Solaris Management Console" |
If the description does not start with "Solaris Management Console 2.1", the package names in the output identify a Solaris Management Console 1.0 package.
Use the pkgrm command to remove all instances of Solaris Management Console 1.0 packages in the following order.
Do not remove any package that has "Solaris Management Console 2.1" in its description. For example, SUNWmc.2 might indicate Solaris Management Console 2.1 software.
If the pkginfo output displays multiple versions of Solaris Management Console 1.0 packages, use the pkgrm command to remove both packages. Remove the original package and then remove the package that has been appended with a number. For example, if the SUNWmcman and SUNWmcman.2 packages appear in the pkginfo output, first remove the SUNWmcman package and then remove the SUNWmcman.2 package. Do not use the prodreg command.
# pkgrm SUNWmcman # pkgrm SUNWmcapp # pkgrm SUNWmcsvr # pkgrm SUNWmcsvu # pkgrm SUNWmc # pkgrm SUNWmcc # pkgrm SUNWmcsws |
In a terminal window, type the following command.
# rm -rf /var/sadm/pkg/SUNWmcapp |
The Solaris Management Console 2.1 software should now function properly. For future maintenance, or if the Solaris Management Console 2.1 software does not function properly, remove the Solaris Management Console 2.1 software. Reinstall the software by completing the following steps.
Use the pkgrm command to remove all Solaris Management Console 2.1 packages and dependent packages in the following order.
If your installation has multiple instances of Solaris Management Console 2.1 packages, such as SUNWmc and SUNWmc.2, first remove SUNWmc, and then SUNWmc.2. Do not use the prodreg command.
# pkgrm SUNWpmgr # pkgrm SUNWrmui # pkgrm SUNWlvmg # pkgrm SUNWlvma # pkgrm SUNWlvmr # pkgrm SUNWdclnt # pkgrm SUNWmga # pkgrm SUNWmgapp # pkgrm SUNWmcdev # pkgrm SUNWmcex # pkgrm SUNWwbmc # pkgrm SUNWmc # pkgrm SUNWmcc # pkgrm SUNWmccom |
Insert the Solaris 9 9/02 Software (SPARC Platform Edition) 1 of 2 CD into your CD-ROM drive. Type the following in a terminal window.
# cd /cdrom/sol_9_902_sparc/s0/Solaris_9/Product # pkgadd -d . SUNWmccom SUNWmcc SUNWmc SUNWwbmc SUNWmcex \ SUNWmcdev SUNWmgapp SUNWmga SUNWdclnt SUNWlvmr SUNWlvma \ SUNWlvmg SUNWpmgr SUNWrmui |
All previous Solaris Management Console versions are removed. The Solaris Management Console 2.1 software is now functional.
