If your Solaris 8 system is connected to storage area networks (SANs), check with your support engineer before you upgrade to the Solaris 9 9/02 operating environment. Solaris 8 systems with the SUNWsan package installed might require special procedures to upgrade to the Solaris 9 9/02 operating environment. To find out if the SUNWsan package is installed on your system, type the following command in a terminal window.
# pkginfo SUNWsan |
If the SUNWsan package is installed, the following information is displayed.
system SUNWsan SAN Foundation Kit |
