If you use the SolarisTM Web Start program on the Solaris 9 9/02 Installation CD to install the Solaris 9 9/02 operating environment, the system might hang on the first reboot after the installation.
Workaround: To avoid this problem, choose one of the following workarounds.
Use the Solaris 9 9/02 Software 1 of 2 CD to install the Solaris 9 9/02 operating environment.
If you use the Solaris 9 9/02 Installation CD to install the Solaris 9 9/02 operating environment, follow these steps.
Insert the Solaris 9 9/02 Installation CD in your CD-ROM drive and begin to install the Solaris 9 9/02 operating environment.
Write down the name of the disk slice when the following message is displayed.
Disk slice disk-slice-name will be used to accommodate a temporary copy of the Solaris installation software. After the files are copied, the system will reboot and the installation will continue. Please Wait... |
Interrupt the installation by pressing Stop-A or by power cycling the system.
The system displays the ok prompt.
Boot the system from the Solaris 9 9/02 Installation CD in standalone mode.
ok boot cdrom -s |
In a terminal window, type the following ls command to determine the physical name of the disk slice you wrote down in step 2.
# ls -l /dev/dsk/disk-slice-name |
This command returns output similar to the following text.
lrwxrwxrwx 1 root root 2 Aug 14 16:56 /dev/dsk/disk-slice-name -> ../../devices/physical-name |
Write down the physical name of the disk slice. Omit the leading text ../../devices from the physical name
Halt the system to return to the ok prompt.
# halt |
Boot the system from the physical device by typing the following command.
ok boot /physical-name |
