NetscapeTM version 6.2.3 base and localization packages are now available in the Solaris_9/ExtraValue/CoBundled/Netscape_6 directory of the Solaris 9 9/02 Software DVD and the Solaris 9 9/02 Software 2 of 2 CD. However, the NS62installer script in the Solaris_9/ExtraValue/CoBundled/Netscape_6 directory installs only the base packages on the system.
Workaround: Use the pkgadd(1M) command to install the Netscape version 6.2.3 localization packages on your system. Follow these steps.
Become superuser.
Insert the Solaris 9 9/02 Software DVD or the Solaris 9 9/02 Software 2 of 2 CD.
Change to the directory where the localization packages are located.
# cd /cdrom/Solaris_9/ExtraValue/CoBundled/Netscape_6/Packages |
Use the pkgadd command. Specify the name of the package you want to install.
# pkgadd -d . name-of-localization-package |
The following localization packages are in the Packages directory.
SUNWcns6 - Simplified Chinese localization
SUNWdens6 - German localization
SUNWesns6 - Spanish localization
SUNWfrns6 - French localization
SUNWhns6 - Traditional Chinese localization
SUNWitns6 - Italian localization
SUNWjans6 - Japanese localization
SUNWkons6 - Korean localization
SUNWplns6 - Polish localization
SUNWptns6 - Brazilian Portuguese localization
SUNWruns6 - Russian localization
SUNWsvns6 - Swedish localization
