The preremove scripts included in the Asian language packages of the Solaris 9 and Solaris 9 9/02 software do not execute properly during an upgrade with Disk Space Reallocation (DSR). If you attempt to upgrade to a newer release of the Solaris operating environment, the following error message is displayed in the /var/sadm/system/logs/update_log file.
Removing package SUNWkwbcp: /a/var/sadm/pkg/SUNWkwbcp/install/preremove: /a/usr/4lib: does not exist pkgrm: ERROR: preremove script did not complete successfully Removal of SUNWkwbcp failed. pkgrm return code = 1 Removing package SUNWkbcp: /a/var/sadm/pkg/SUNWkbcp/install/preremove: /a/usr/4lib: does not exist pkgrm: ERROR: preremove script did not complete successfully Removal of SUNWkbcp failed. pkgrm return code = 1 Removing package SUNWcwbcp: /a/var/sadm/pkg/SUNWcwbcp/install/preremove: /a/usr/4lib: does not exist pkgrm: ERROR: preremove script did not complete successfully Removal of SUNWcwbcp failed. pkgrm return code = 1 Removing package SUNWcbcp: /a/var/sadm/pkg/SUNWcbcp/install/preremove: /a/usr/4lib: does not exist pkgrm: ERROR: preremove script did not complete successfully Removal of SUNWcbcp failed. pkgrm return code = 1 Removing package SUNWhwbcp: /a/var/sadm/pkg/SUNWhwbcp/install/preremove: /a/usr/4lib: does not exist pkgrm: ERROR: preremove script did not complete successfully Removal of SUNWhwbcp failed. pkgrm return code = 1 Removing package SUNWhbcp: /a/var/sadm/pkg/SUNWhbcp/install/preremove: /a/usr/4lib: does not exist pkgrm: ERROR: preremove script did not complete successfully Removal of SUNWhbcp failed. pkgrm return code = 1 |
Workaround: Ignore the error message.
