In the Solaris 9 9/02 operating environment, the Kerberos version 5 global mechanism includes privacy support. Therefore, the Kerberos domestic mechanism is not needed. If you installed the Kerberos domestic mechanism that is located in /usr/lib/gss/do/mech_krb.so.1 on a Solaris 8 system, remove the Kerberos domestic mechanism before you upgrade the system to the Solaris 9 9/02 operating environment.
Workaround: Follow these steps before you upgrade to the Solaris 9 9/02 operating environment.
Type the following command to determine if the Kerberos domestic mechanism is installed on the system.
% pkginfo | fgrep ' SUNWk5' |
If the output of this command includes any SUNWk5 package names, the Kerberos domestic mechanism is installed on the system. Go to step 2.
If the output does not include any SUNWk5 package names, the Kerberos domestic mechanism is not installed on the system. Skip the rest of these steps. Upgrade the system.
Back up the /etc/nfssec.conf and /etc/gss/qop files by typing the following command.
% tar -cf /var/tmp/krb_config_files.tar /etc/nfssec.conf /etc/gss/qop |
Verify that the files are backed up by typing the following command.
% tar -tf /var/tmp/krb_config_files.tar |
Remove each package that is listed in the output of step 1.
% pkgrm package-name package-name package-name |
Upgrade to the Solaris 9 9/02 operating environment.
The upgrade program updates the global Kerberos mechanism code and enables Kerberos privacy support.
In a text editor, change the following lines in the /etc/gss/mech file.
Uncomment the following line.
kerberos_v5 1.2.840.113554.1.2.2 gl/mech_krb5.so gl_kmech_krb5 |
If necessary, add the previous line to the /etc/gss/mech file.
Remove the following line.
kerberos_v5 1.2.840.113554.1.2.2 do/mech_krb5.so do_kmech_krb5 |
Restore the /etc/nfssec.conf and /etc/gss/qop files by typing the following command.
% tar -xf /var/tmp/krb_config_files.tar |
