The following error message is displayed when memory is low:
CIM_ERR_LOW_ON_MEMORY |
You cannot add more entries when the Common Information Model (CIM) Object Manager has run low on memory. You must reset the CIM Object Manager Repository.
Workaround: To reset the CIM Object Manager Repository, follow these steps.
Become superuser.
Stop the CIM Object Manager.
# /etc/init.d/init.wbem stop |
Remove the JavaSpacesTM log directory.
# /bin/rm -rf /var/sadm/wbem/log |
Restart the CIM Object Manager.
# /etc/init.d/init.wbem start |
When you reset the CIM Object Manager Repository, you lose any proprietary definitions in your data store. You must recompile the MOF files that contain those definitions by using the mofcomp command. See the following example.
# /usr/sadm/bin/mofcomp -u root -p root-password your-mof-file |
