Solaris 9 (SPARC Platform Edition) 9/02 Release Notes
SUNWsdocs Package Necessary to Remove Other Documentation Packages
If you remove the SUNWsdocs package, then try to remove other documentation packages, the removal fails. This problem occurs because the SUNWsdocs package is installed with any collection and provides the browser entry point.
Workaround: If you removed the SUNWsdocs package, reinstall the SUNWsdocs package from the documentation media and then remove the other documentation packages.
